These close up photos show how deep and rich the paint job has turned out. Very nice Bo!
The "after" trim looks great. Probably silly question, but did they polish it prior to cerakoting?First, Speedway finally finished (part of) my trim cerakoting. He forgot to do one piece (grrrr...) so that gives me an opportunity to show the before and after.
Yes they did. You can sort of see it in that "before and after" pic in post 283. I think if you click on it, it will enlarge.The "after" trim looks great. Probably silly question, but did they polish it prior to cerakoting?
Thank you Erik.Great Progress. Starting that rebuild process is sooo rewarding!
That Ceracoat looks awesome. It's not available in Europe as far as i can tell. Anyone knows what it is, technically? And if comparable alternatives exist in Europe?
I know Alu can be polished, but it requires ( a little) attention once in a while; I like the fact that the Ceracoat gives us one less item to take care off.
And do I see correctly that you dare to use the long pliers from the e9 toolkit? I bet is is the most valuable pliers in your garage!
Still curious to see what you did with holes on the edge of the trunklid... I couldn't help but notice that the pic in post # 283 was just cut short of the trunk lid edge ...
The suspense is killing’ me! So, then….how did you recover the pieces??!Dashboard recover part I
My dashboard was a bit of a dilemma because it was overall in very good condition. But it had three things I didn’t like: two small cracks which 98% of people would never notice but also the infamous fasten seatbelt sign which left big holes in the center.
Having the windshield out is both a blessing and a curse. It gives you access to all kinds of things which means you feel obligated to take advantage of this unique opportunity to repair some things that would be much more difficult to deal with with windshield in place. So I decided to take the plunge.
First step was to remove the old vinyl. As it turns out it’s not really vinyl but some sort of plastic that was formed around the foam. Using a heat gun and some scrapers it was not too difficult of a job. Once I had the foam laid bare, I filled the holes from the fasten seatbelt sign as well as several other areas where the original foam had not completely filled the space. I tested several different options and finally chose Loctite Tite Foam for having the closest cell structure and density to the original. It is also exterior rated and uv resistant. Then shaped it with a random orbital sander.
View attachment 143478 View attachment 143477 View attachment 143479 View attachment 143480 View attachment 143482
After a bit of research I found some marine grade exterior four-way stretch vinyl with a texture very similar to the original. I plan on testing it in the next couple of weeksThe suspense is killing’ me! So, then….how did you recover the pieces??!
This sounds very interesting. I've considered recovering the E3 dash, which looks a little easier than an E9, but if I wait long enough my urge will probably pass.After a bit of research I found some marine grade exterior four-way stretch vinyl with a texture very similar to the original. I plan on testing it in the next couple of weeks
I too am waiting to hear how it goes.marine grade exterior four-way stretch vinyl
