Well I've abandon all timelines. With the rise in temperatures come more yard/house projects. Slow and steady wins this race! I envy those that can spend 8 hours pulling parts off of a car. I'm lucky to spend 30 minutes...
I had great luck removing the chrome window cap on the driver's side door. At some point someone caulked the passenger cap to the glass. I should have taken a pic of the trim "taco'd". This is a 30 second attempt to straighten. I don't really need this part, but I'm confident that it can be straightened out if needed. I tried to line it up to a straight line to illustrate how bent it is. I long narrow screwdriver used to pry up from the center would help quite a bit.
The lower rear window chrome is secured with one screw. The screw is accessed with the door open. See the rusty discoloration on the rubber block - that is where the screw threads into. I taped the screws to the trim piece.
You will find that the chrome sits on a rubber bumper. This bumper is also held on by a small screw. One of mine came right off the sheet metal and is still connected to the chrome trim. The other didn't budge and the screw head will require drilling.
The wiper linkages are easily removed. A set of 22mm nuts and corresponding washers keep the posts bolted in. You should have three parts on each side. I recommend a six point socket, as the nuts are plated and not terribly stout.
The linkages are covered by the cabin intake cover. The cover is held on by two 8mm screws with little spring clips on the engine side of the firewall. Be sure to catch these before they fall.
The linkage is connected to the motor with 3x 10mm nuts. These nuts contain both plastic and metal washers so be careful not to lose.
I received numerous PM's about the wiper linkages. Apparently they like to break. I was honestly a bit apprehensive to sell but mine check out. I can't hoard parts. A local PNW member who is active on this board was desperate to get his wipers back on for the car show season. His threaded splines somehow separated from the wiper shafts. Stan mentioned that his cracked off, so I hope that mine survive. Searching this site, sold eBay listings, and a pending CL add showed linkages and motor for $150. I kept the motor and sold the linkage setup for $100, less $10 in shipping.
So far I've sold four parts and the car is 10% paid off. When all is said and done, I'll need to factor in storage. I'll stop dwelling on that.
Total Sales: $310
Remaining: $3,090
