Back on to the harness...
Removing the screw near that back of the brain allows a plastic panel to pop open. This gains you access to the main ~21 pin blade connector for the brain.
The connector - the black part slides out. The extra millimeter or two will be helpful when pulling the connector through the frame:
Wrap the entire connector in electrical tape. line up the fuel pump relay plug on the end of the blade connector and wrap that up also (not seen in pic):
After you pass the harness through the rear seat, and the reinforcement that's under the front seats, you will begin to fish the harness through the frame hole. It takes several trips, pushing a bit from the passenger floor, then pulling a bit from the engine compartment. The blade connector will pass through without issue on both ends.
You end up with this. I've mentioned it before, but WD-40 makes a great wiring harness cleaner. Look at that shine!
The CSI intake manifold is date stamped:
